Browse Forums Windows & Doors 1 Nov 23, 2017 3:16 am Hello, There are two doors in my room. The second door is between my room and the room of the other person. It is never used and is always closed. But there is noise coming from the other room. Can you explain how I can insulate the door to make it as soundproof as possible? Since the door will be removed and replaced with a wall at some later time, any temporary measures can be taken now regardless of the damage to the door. I need to find out what method works best in terms of reducing noise. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Sealing a Door to Make It Soundproof (Regardless of the 2Nov 23, 2017 7:15 am If you really do not care about the door, the best insulation would be to attach soundproof batts over the whole door and frame, making sure to cover the gaps on all four sides. How you attach these is flexible, but if it was me, I would build a box out of cheap MDF that fits the batts and allows the box to be screwed onto the sides of the architrave. Then paint and you have a really good temporary solution that is still reversible if necessary. Re: Sealing a Door to Make It Soundproof (Regardless of the 3Nov 24, 2017 4:50 am Thank you for explaining how noise can be reduced. I understand that I can use adhesive strips along the perimeter of the door, and a door sweep at the bottom. The door can be wrapped with some material to be closed tightly. Perhaps I should also use a sealant to seal any remaining openings. Some stores sell seal kits, as they are called, which are sets of things needed to seal a door. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1631 Not sure who you're building with, but I moved in recently to a 11month scheduled, 8 month actual build on the South coast/Illawarra NSW 3 5911 |
