Browse Forums Windows & Doors 1 Oct 12, 2017 4:23 pm I've recently purchased a home with a couple of older style sliding windows. They appear to have a pin in them to prevent them from opening. Any ideas on how best to fix it so they are openable? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice needed on how to open this window 2Oct 26, 2017 2:33 pm Hi This looks like there is a piece of dowel in the track, a common method of limiting opening. Just remove it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Advice needed on how to open this window 3Oct 26, 2017 3:50 pm Thanks for the reply. I should have added to my request that I had removed the dowel when I tried to open the window but it doesn't budge. I suspect that the lock is broken and it's been stuck in a locked position. Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3585 Hello! We have a very large open plan living room and wanted to get layout options, and furnishing ideas for this space. Currently there is only a… 0 9328 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
