Browse Forums Windows & Doors Re: Changing internal door to sliding cavity 2Aug 25, 2008 4:33 pm I think you will have to rip out the origional internal door and architraves if you are going to do this. The door frame for a cavity slider is totally different to a standard door frame (standard door has hinges, cavity sliding door has overhead rollers).
You will need to build a cavity for the 'cavity' sliding door, which will entail building a second wall. Consequently this second wall will eat into the adjacent room area. Good luck with it. Pat the draftie. Re: Changing internal door to sliding cavity 3Aug 25, 2008 8:18 pm You don't need a second wall though you will need to remove the gyprock from at least one side of the wall. You will need to know you stud size before ordering (70mm or 90mm framing)
Its a fairly straight forward fit unless the wall is load bearing. Finishing them off neatly (architrave etc.) can be a little more fiddly than an ordinary door. Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5536 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 |
