Forum Windows & Doors 1 Aug 25, 2008 7:33 am We are in a bit of a dilemma... We have added a wall to our Lounge to close off and create a Theatre Room. Problem is to retain the 5 star rating we've been told there needs to be a 2100mm wide space in the wall to allow natural light to enter the room. After handover, we were originally going to put a sliding door in to close off - but now believe it is too wide, so bi-folds are the only option... Any ideas?
Also, how difficult is it to install a sliding door into an existing wall/space? Thanks. Re: Sliding Door or Bi-Fold Doors? 2Aug 25, 2008 11:11 am Instead of Bi fold doors for our home we are putting in sliding aluminium stacker doors. Cheaper than Bi folds and also can have flyscreens.
It would be cheaper to have it done now rather than later, although it can be done later if you so wish but it will cost! Finally Designing and building the home I always wanted to! Re: Sliding Door or Bi-Fold Doors? 4Aug 25, 2008 11:44 pm We are doing a similar sort of thing with our living room, we are going to put in custom made wall hung sliding doors. You can buy the track/hanging section and then get the doors made to suit the opening ie: 2 x 1100 wide doors in your case. Building Standards; Getting It Right! Camhaw It looks like they intended to have a sliding door with a , which incidentally requires a Balustrade. Check to see if this was changed for whatever reason and you… 1 349 ![]() We asked for this too (I can't remember exactly what the builder said as it was more the 2yrs ago now) but I think it was something to do with drainage/ water not coming… 1 203 |
