Browse Forums Windows & Doors 1 Jun 13, 2017 2:45 pm Hi Questions are welcome... please don't think that there are loose ends on here, where questions don't get answered, every question has been fully answered "off" the forum in messages. This is because there is a lot of detail to be communicated. So ask away... technical, aesthetic, options, quality... the only stupid question is the one you don't ask. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Questions... 2Jun 13, 2017 4:11 pm I'll bite. What is the height of a standard brick (230x110x76) window sill should I account for? i.e. Say I want a 700mm high window which means an opening of 9 brick courses (772mm), to reduce the size of the infill between the lintel and window, what height window should I order( noting that I there will be a downwards sloping brick sill)? 730mm? Secondly, does EcoEco manufacture stacker doors to suit a 4200mm wide opening? Re: Questions... 3Jun 14, 2017 3:11 pm Hi JB1 Not sure I entirely understand. You want to know what height window to order when the opening is 700 to negate the need for an infill at the head? We advise minimum 10mm clearance at the head to take account of settling. And 10mm at the sill to be able to pack the window.. So my guess would be 750. At 2110 door head height, means the window will be 2110-750 = 1360 above the floor.. We supply stacker doos to 6000 wide as standard, 6 panels, 4 moving, opening in the centre. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Questions... 4Jun 14, 2017 3:20 pm Actually, say the opening is 772mm (9 brick courses), what is the max window height you fit after accounting of the height of the brick window sill and any clearances. Re: stacker door. I was looking for a 3 panels, 1 fixed and 2 sliding. Re: Questions... 5Jun 15, 2017 10:41 am Brick sills don't have standard angles, in Qld they are often square. The clearances would be 10mm all round. But if you are careful you can make it 10mm overall on height. So ignoring the angle on the brick sill, the window could be 762 high. What height is the stacker? "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Questions... 6Jun 15, 2017 12:19 pm Thanks. Height of stacker is 2400mm. Question about awning windows. If they are more narrow (850mm) and tall (2100mm), can you place the hinges and winder on the side? I.e. opens out like a book. That way you don't have bend down to wind it open/closed. Re: Questions... 7Jun 15, 2017 1:17 pm The stacker... yes, depends when you want it. The window is called a casement, yesy, we can make that in a single sash, double glazed. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Questions... 9Jun 15, 2017 1:32 pm yes, it takes a flyscreen on the inside. The opening has no effect on the flyscreen. Come and see it. 129 Abbott Rd, Hallam. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Questions... 11Jun 15, 2017 4:12 pm OK. Look forward to seeing you. Yes, we have the stacker on display and a casement. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Questions... 12Jun 16, 2017 10:46 pm ECOECO So ask away... technical, aesthetic, options, quality... the only stupid question is the one you don't ask. Thanks Ed Ok I'll bite... Which is easirer/cheaperer/betterer? A 2100 tall window on a 300 wall/ledge/sill thing or a 2400 tall window on the floor? Ceiling height being 2550 and 2700. What is under the window if it's set on the floor? And, are square set window surrounds different from normal architrave ones? (haven't googled that yet) Re: Questions... 14Jun 19, 2017 10:18 am 2100 tall starting at 300 v. 2400 tall on the floor... Obviously the 2400 tall window will be dearer, but whether that actually pans out in the total cost depends on the bricks/lightweight materials that repalce the 300. Operationally, if it is a full sash awning window, then 300 off the floor makes it easier to operate the chain winder. With the window on the floor, your choice is to leave off the bottom reveal and run the floor covering into the window recess, or have the reveal level with the plaster and the floor covering ends at the plaster. If you don't want architraves, then a product called Ezy Reveal is often used to form a neat corner with the plaster. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10470 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4494 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8235 |
