Browse Forums Windows & Doors Re: Questions... 14Jun 19, 2017 10:18 am 2100 tall starting at 300 v. 2400 tall on the floor... Obviously the 2400 tall window will be dearer, but whether that actually pans out in the total cost depends on the bricks/lightweight materials that repalce the 300. Operationally, if it is a full sash awning window, then 300 off the floor makes it easier to operate the chain winder. With the window on the floor, your choice is to leave off the bottom reveal and run the floor covering into the window recess, or have the reveal level with the plaster and the floor covering ends at the plaster. If you don't want architraves, then a product called Ezy Reveal is often used to form a neat corner with the plaster. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10482 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4507 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8255 |
