Browse Forums Windows & Doors 1 Apr 25, 2017 12:48 pm Hey guys, first time posting here so hopefully I've found the right place. I've found a vault room inside an old foundry to use as an art studio, but it really needs a second exit installed. The door will allow light, air and act as a fire escape as well. However I wanted some advice on the structural integrity before committing myself to anything. This is the wall in question: https://ibb.co/g7PBLk The room was a vault, so the wall is double brick on the outside, and equally as thick concrete on the inside, with 2 layers of steel reinforcing mesh. The building is 2 storeys, but with very high factory ceilings. All concrete walls and I believe a tin roof. The vault is concrete and brick on all 4 walls, ceiling and floor. Inside the wall (this is a hole that was cut for an air conditioning unit, you can see in the above photo): https://ibb.co/e5Z0D5 Ideally I would love to put in a sliding glass door (basic patio/back door variety). But that would require a 2m wide hole, or thereabouts. I'm wondering if this would be safe to do? Any advice on how to proceed would be awesome. Many thanks. (sorry I couldn't insert the images for some reason) Re: Installing a door in solid brick vault...? 4Apr 27, 2017 12:11 pm Sure, try one of those places that offers you 3 quotes. Welcome "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 |
