Browse Forums Windows & Doors 1 Aug 15, 2008 12:36 pm Don't even know where to start. Building an extension for a veterinary clinic, the architect has drawn a 900 swinging door into the surgery room, and a 900 H&L door to the xray room, Search everywhere for a commercial door company who manufactures hospital like swinging doors,
Anyone got any ideas. anything would be helpful cheers Doug Re: Veterinary clinic internal Swinging Door 2Aug 15, 2008 12:54 pm http://www.ferret.com.au/c/Coldshield/Flexible-PVC-Doors-from-Coldshield-n781442
How about see-through swinging doors? Located in QLD. Where are you ? Maybe they can put you on to a supplier in your state ? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Veterinary clinic internal Swinging Door 4Sep 15, 2008 11:11 am Dougmega, You may be looking for just the hinge that gives you the swing on the door. Its called a Parliament HInge and you can then custom the door as you need but attach this hinge. Check the site I have attached and see if you have any luck. Even ring the suppliers they will be able to point you in the right direction.
http://www.ilcaustralia.org/search4.asp ... 12&page=30 Re: Veterinary clinic internal Swinging Door 5Oct 01, 2008 10:12 pm Try asking someone at the AVA, or put a post up on their website.
Our sx door swings both ways, & has a glass panel in the top, so they are definitely available. Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5403 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7934 3 10199 |
