Hello, I have a relatively narrow passage (little more than a standard door width) with a conventional swinging timber door.
The door is usually left open but unfortunately the conventional door handles prevent the door opening fully (against the wall) on one side and of course on the other side the door handle protrudes into the passageway (which has been responsible for the odd bruise).
The passage would be effectively wider and look better without door handles.
Hence I was hoping to replace the door handles with round flush pulls and a roller latch.
Has anyone done something similar and know who might manufacture or supply appropriate flush pulls and roller latch?
Thank you.
Flush Door Handle Solution for (narrow) Passage Door
Newbie question for flooring options. We are thinking of changing the flooring for bedrooms and passage area. Last time we looked at flooring options was almost 8years…
23/05/2023
6
Black on light wood does look good. Not sure if it will be as long lasting as a steel finish?
4/09/2023
2
The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might…
