I have take on a project of converting my shed into a fully lined rumpus room. As you can see in the photos I have installed the windows, I now need to install the box around the windows so I can bring them out to where the framing and plasterboard will sit once the walls are all done. I was going to use 12mm maranti for this so I make the box first then put it around the window and how do I connect it to the window? Any help would be great. Thanks in advance ?
Window Timber Surrounds
1
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
14/06/2023
1
that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink
