Browse Forums Windows & Doors 1 Aug 06, 2008 7:49 pm Hi
Can someone please advise how to check if a window / door is double glaze or not? I think i have seen a post talking about it with picture as well, but i just cant find that post now, appreciate your help, thanks Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: How to know it is double glaze? 2Aug 06, 2008 8:23 pm If you look at the edges of the glass, you will see a metal or plastic piece between the outside and inside pane. It goes all the way around. It's quite distinctive once you've seen it.
It has tiny holes or slits in it. These hold the desiccant that makes sure that there is no moisture between the panes. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: How to know it is double glaze? 3Aug 07, 2008 6:29 pm Thanks Casa, will take note of that... have finally found some pic as a guide too... Thanks Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36934 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3626 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 29741 |
