Does anyone have experience with tinting double glazed windows?
I'm interested in reducing UV effects on furniture and floorboards etc
Thanks
Browse Forums Windows & Doors Re: Tinting double glazed windows 2Mar 02, 2017 3:42 pm Hello Gaudi, Are these going to be new windows or existing ? If these are new products you can specify laminated glass as part of the IGU which can assist in reducing the UV radiation by ~99%. UV Radiation isn't the only cause of fading as the heat itself can also assist in bleaching of furniture and flooring. Having said that, the laminate and reduction of UV will obviously make a substantial difference. There are also other speciliased glass coatings which can assist in reducing the solar heat gain coefficient (SHGC) through the pane in combination with laminates to provide further protection. If they are existing windows, you want to be careful about tinting over float glass (i.e. non-toughened). Whilst toughened glass is more resilient, float glass with tint will absorb heat differently across the pane and can be at risk of causing thermal stress which will crack the glass unit. Hope this helps! Thanks, Kurt Miglas Miglas High Performance Composite Double Glazed Windows Phone 1300 MIGLAS Fax (03) 9728 3555 http://www.miglas.com.au Re: Tinting double glazed windows 3Mar 05, 2017 8:12 am Thanks you so much Kurt for your expert advice. This does helps a lot. I thought of tinting or coating after I got the keys to my house in Jan. I wish I had thought of coating the windows and investigated this pre project build. They are existing windows. Most of my double glazed windows are toughened. Just one is not. So toughened double glazed glass is OK to tint? Thanks again Re: Tinting double glazed windows 4Mar 06, 2017 9:24 am Hello Gaudi, Adding the tint afterwards will always increase the risk of thermal stress/cracking - however in toughened glass its very unlikely to occur. I would suggest contacting your window supplier to discuss with them and make sure these changes will not impact upon your warranty. Thanks, Kurt Miglas High Performance Composite Double Glazed Windows Phone 1300 MIGLAS Fax (03) 9728 3555 http://www.miglas.com.au Re: Tinting double glazed windows 5Mar 08, 2017 6:08 pm [quote="Miglas Windows"] I would suggest contacting your window supplier to discuss with them and make sure these changes will not impact upon your warranty. Thanks Kurt!!! The company have not been keen to put anything in writing so your tip re: warranty is good. Best wishes 5 19556 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 17163 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3948 |
