Browse Forums Windows & Doors 1 Jun 26, 2016 9:28 pm Hi all Just wondering how much your corner stacker doors cost you? Did you have to have reinforcements put in above the door? Thanks heaps!! Re: Cost of corner stacker door 2Jun 26, 2016 11:00 pm The cantilevered ceiling where the corner stacks meet will need to be engineered Re: Cost of corner stacker door 3Jun 29, 2016 6:10 pm We have a large steel beam above one of the doors to support the roof. Not sure of the cost of the this beam or stacker doors on on their own, was factored into the cost of the whole addition. All I can say though is do it. It looks fantastic when open and is great when entertaining. Good luck Re: Cost of corner stacker door 4Jul 03, 2016 12:28 am It's very closely . We originally have sliding door on one side and a large window in the rumpus . I wanted to convert the window and sliding doors to a corner bifold door. I was advised the areas need to be re-engineered. It will cost me around 10K to convert. It was way too price for us so we decided to hange both area to stacker doors in black aluminium frame . It was around 600 each to upgrade . The actual Sure looks like the type of track that I fitted to my house. My supplier said that the underside has a tray which drains to the front. They cut vertical slots in it. So as… 6 7900 Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3994 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12390 |
