I did thank you very much!!! Have replied as well
Browse Forums Windows & Doors Re: Which window frame colour? 21Apr 18, 2016 9:12 pm Tracey70 Did you get the pictures i sent you? I did thank you very much!!! Have replied as well Re: Which window frame colour? 23Apr 23, 2016 9:12 pm Alexxdavid Frye I'd go black. It goes with everything and will give your facade a pop as everything else is very light. Even with the Wood look triple garage? Especially with the wood! I have light bricks (white mortar). Dark contrast brick on porch/balcony. Surfmist cladding on front upper facade. Light tile roof (close to 'Evening Haze'). Timber-look garage door. Black windows. = Awesome ❤️ Windows are the eyes of your house. Black defines them. Like pretty eyeliner and mascara. Says me ?? Re: Which window frame colour? 24Apr 28, 2016 3:50 pm Between night sky and monument which gutter would go better? Re: Which window frame colour? 26Apr 28, 2016 5:08 pm Will the night sky be better with the black window frames? Re: Which window frame colour? 29Apr 28, 2016 6:48 pm Tracey70 What color fascia were you having? Same as guttering? What colour is your brick as your house won't be rendered all around will it? Fascia is surfmist Render all around surfmist with dune as a contrast Re: Which window frame colour? 30Apr 28, 2016 8:16 pm Alexxdavid Tracey70 What color fascia were you having? Same as guttering? What colour is your brick as your house won't be rendered all around will it? Fascia is surfmist Render all around surfmist with dune as a contrast Nightsky would be the best i think otherwise the front may look to busy introducing another color. Re: Which window frame colour? 31Apr 28, 2016 10:33 pm Alexxdavid Will the night sky be better with the black window frames? Most definitely! Night Sky = black 1 14517 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8090 Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11369 |
