Browse Forums Windows & Doors 1 Apr 06, 2016 6:00 pm We're building under the flight path. After our acoustic survey we are required to have the following Windows: Bedrooms - 6.76 laminate glass Living Areas - 6.38 laminate glass OR 6/8/4mm double glazing What is your suggestion for the living areas? Or should we go 6.76 laminate glass throughout the whole house? KDR - Under the Flight Path (Dennis Family Homes) KDR Under the Flight Path - Dennis Family Homes (Hawkesdale) Laminate or double glazed Windows? 3Apr 07, 2016 6:54 pm Definitely double glaze with an argon gas gap! Not only will reduce noise but thermally beneficial too! Personally I'd go higher than the minimum required. Check out the insulated glass units http://viridianglass.com Re: Laminate or double glazed Windows? 6Mar 20, 2017 2:20 pm rondy We're building under the flight path. After our acoustic survey we are required to have the following Windows: Bedrooms - 6.76 laminate glass Living Areas - 6.38 laminate glass OR 6/8/4mm double glazing What is your suggestion for the living areas? Or should we go 6.76 laminate glass throughout the whole house? KDR - Under the Flight Path (Dennis Family Homes) Actually the total thickness of glass makes the biggest difference in noise attenuation. Argon, gap size and laminate are just tweaks. So double glazing is a 2 fold benefit, being acoustic and energy improvement. I prefer to see the acoustic report as there are many ways to reach the Rw (attenuation) requirement, and the prescriptive approach is usually expensive, and ignores window performance. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16227 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16146 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6330 |
