Browse Forums Windows & Doors 1 Apr 04, 2016 10:39 pm Hi all. We'll be installing a 1500 x 2700 custom pivot door made out of rough sawn blackbutt timber, similar to timber found at Schnitz/Nandos restaurants. I've been looking for months to find a custom door pull handle rather than just going a vertical bar. I will have a separate deadlock so the purpose of it will be to pull and push. I am after something like these: http://www.firstimpressionsint.com/prod ... s/delano-1 http://www.firstimpressionsint.com/prod ... /boulder-3 http://www.pushorpull.com.au/12-browse- ... 29-peking- Something flat would be ideal. It doesn't even have to be a designated handle. It could be a recycled material that is flat which we can mount brackets on so we can fix it to the door. Any ideas or suggestions would be most welcome as I have 1 week left to come up with a solution. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB Re: Where to source a custom entry door handle? 2Apr 05, 2016 7:28 am That's gonna be one awesome door! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Where to source a custom entry door handle? 3Apr 05, 2016 2:13 pm No ideas where to help you find it but i like the look of your first picture. I can see that on your build. Build thread: viewtopic.php?f=38&t=75302 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11383 |
