Browse Forums Windows & Doors 1 Nov 05, 2015 4:23 pm Hi all, I have two upstairs sliding doors that face southwest and get a lot of summer sun. They open onto a balcony that has dark tiles and reflect a lot of heat. I need to do something as they're the main cause for heat buildup in the upstairs part of the house on the warmer days. These are my priorities: 1. Summer insulation against heat 2. Winter insulation against cold 3. Noise Privacy and security are not concerns. There is less than 100mm between the top of frame and eaves so I haven't found a suitable blind/shutter. Double glazing (most likely retrofit but may be open to complete replacement) would be my preferred option because of the additional winter and noise insulation properties, but i'm of the belief that it won't help against direct sunlight. Am I right in thinking this? So I've been looking at a thermal film. Is this the best option? It's hard to work it all out when each supplier tells me their method is best. thanks. Re: Window insulation options 2Dec 04, 2015 5:17 am Its pretty technical question which you mentioned here I think you should consult this glazier http://safetyglassmirrors.com.au/ he is expert in all as recently he also fixed windows at my house so I am 100% sure he will provide you better and economical solution. Re: Window insulation options 3Mar 04, 2016 9:12 am Double glazing will help with conducted heat, ie from the air being hot outside, but not so much from radiated heat, (direct sunlight, and radiated heat from hot tiles) To tackle the radiated heat, you'd be looking at shutters, awning, thermal blinds or curtains. A low-E glass or film will also help. The best solution would be new double-glazing with low-E glass, and/or with shutters on the outside and thermal curtains on the inside. The cheapest solution is probably sticking some aluminium foil across the windows. Re: Window insulation options 5Mar 28, 2016 12:54 pm We have just installed windows laminate/film and changed from double hung to awning (used Stegbar), our main concern was noise from a busy road. The cost difference between this & double glazing was significant and seems unjustified unless in a cool climate. Good luck making your decision! Re: Window insulation options 6Apr 21, 2016 9:23 pm Getting your window ready to combat harsh weather is of paramount importance. I understand your concern. I would like to share few methods which I employed in my house to get my windows insulated from heat and cold. For winter ,some simple methods to insulate your window from cold include using layered curtains to shrink-wrap film, rubber weather sealing , window insulation sealing or a window insulation film. You can also insulate your window from cold using cellular shades , layered curtains with heavy fabric and if still you are not satisfied go for draft snakes which is made by sewing a tube of fabric to fit the window width. Later fill it with dried rice. One of my friend has been using bubble wrap from last 3 years and is pretty satisfied with it. If budget is an issue go for low cost options like caulking and weatherstripping in the sash. Summer, beat the heat using bubble wrap or by weatherstripping your windows. Using shutters is a very effective method to keep heat at bay. Last year my friend, Edward had his windows insulated. If I am not wrong he mentioned about a windows and doors company NorthTech Services. For Tips do take help from http://northtechwindows.ca/2015/12/07/t ... he-winter/ Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12003 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6454 Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20138 |
