Browse Forums Windows & Doors Re: New build, I sit possible to supply own windows? 2Nov 07, 2015 6:34 am Hi Suzi, There are likely experts on here that will be able to provide you more detailed guidance but I reply as I am going through this exact issue right now on my new build and thought it may help you. I guess in short it depends on whether you are going down a bulk build/house and land package type route or a more custom route. For me, our build is architect designed and thus full custom. We will tender to local boutique builders and I will more than likely be specifying in my inclusions that the builder must work with a particular window supplier for the window schedule where the window brand, specs and technology will all be locked down. This will ensure we get exactly the performance characteristics and look we need for the home and may also help remove price deviation from such a large component of our build cost. I suspect if you are working off set plans from a bulk builder this may not be a path open to you as they tend to have supply agreements already in place for the plans they offer so they can achieve pricing that is attractive in market consistently. But hey it doesn't hurt to ask, if you don't ask you don't get right. Regards, Nick That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36960 0 9810 |
