Browse Forums Windows & Doors 1 Sep 07, 2015 9:12 am Hi guys, I have some old sliding windows with a channel between which the draught comes through. There is a seal on the end of one pane (see attached) and meant to be one on the other but there isn’t. I’ve searched high and low and can’t find these seals anywhere (tried Clark Rubber, Bunnings, Masters, a couple of local glazers, online). I’ve been told they don’t make them anymore but I'm wondering if any has any idea if and where I can find them. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Len Re: Weather Seals for Old Metal Windows 2Sep 07, 2015 9:27 am Hi Len83 Welcome to the forum and thanks for the photos To achieve a positive outcome to your enquiry also try to put up a close up photo of the seal and I recommend a cross sectional sketch with dimensions (hand drawn) That way you will increase the possibility of someone recognising an alternative fix. etc Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6512 Fine with me... just let 'em step in with some affordable (but good) gear... 12 5485 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 |
