Sorry if this is a repeated thread, I'm sure i can't be the first person with this question but my searches have found nothing for my problem.
We're currently renovating out home, which has a single brick internal wall seperating two living areas. The walls are plastered not drywall and this particular wall has two lovely holes 'cut out' of it like internal windows. Without properly measuring i would guess they're about 90cmx60cm each (and as deep as a brick plus the plaster each side).
I want to fill both these holes as they're pretty ugly IMO and we're trying to modernise the home, my question (finally) is how best to do this? I can find loads on information on filling such holes in drywall walls but not brick/plasterwalls.
My idea was to screw a wooden frame made of trimmed down 4x2 into the holes and place drywall over it so it's flush with the existing wall. I would then use a gap filler and smooth coat to get an even finish and paint etc. From what I've read the drywall tape that is usually used is unlikely to stick to the existing plaster, plus I'm not sure of why it is used and whether it woukd be needed as the existing walls are plaster. I'm partly not sure if a mixed approach of plaster/ drywall is the best, but can't think of any other way to do it.
I'm a reno rookie so sorry if things don't make sense, I do consider myself fairly handy though so with some guidance I'm hoping to get this problem sorted
Thanks in advance for any help.
