Browse Forums Windows & Doors 1 Jul 06, 2015 7:35 pm Hey all, just wondering if anyone can provide some advice... We had requested our builders to provide an external swing door from our living room to the side yard of our double storey home during the contracts phase and this was approved a few months ago. We are now finally nearly ready to start building and have been advised they can't do it as "it is a habitable area and will not be weather proofed. Water may come in when it's raining"!? Their alternatives are to put in a glass sliding door which won't work as it will take up too much wall space or build an extra alfresco which will be 1.5 m wide by nearly 5m long and costs several thousand dollars. Has anyone else come across this or know what we could do to get around it? We don't really understand the problem but this side door is pretty key to our plans for outdoor entertaining and gardens. We do have a swinging external door to our laundry but apparently this is okay as it's not a "habitable area". So confused! Building the Sahara Q2 with Henley Re: External door to habitable area 2Jul 06, 2015 9:01 pm A standard swinging door doesn't seal up well against wind driven rain. A bit of water entry isn't usually so much of a concern in a laundry or foyer. I think you can get framed swinging door sets from some window manufacturers though that do seal, similar in style to bi-fold doors. Re: External door to habitable area 4Jul 14, 2015 9:53 am CatE05 Thanks for your reply OneJohn. We've decided to install a door sized window and will retrofit the door once we've got handover. What you want is a French door i.e open out... ours seals well... I am sure others have them... maybe timber will be a problem as it warps over time. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 Thanks for your thoughts. Do you feel your louvre sidelite security mesh is safe? I was thinking no window at all so no one can see if I'm near the front door, shadows… 2 806 Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4294 |
