Browse Forums Windows & Doors 1 Jun 20, 2015 9:27 am Timber is hard to maintain. If I choose aluminium frame, is it worth throwing a lot to have double glazing windows as aluminum will lose heat quickly and is the weakest point in the chain. Other options like Aluminum broken is costly. Is there any cost effective to maintain the energy efficiency? Re: Is It Worth Double Glazing for Aluminium Frame Window? 2Jun 21, 2015 4:10 pm yhfg27 Timber is hard to maintain. If I choose aluminium frame, is it worth throwing a lot to have double glazing windows as aluminum will lose heat quickly and is the weakest point in the chain. Other options like Aluminum broken is costly. Is there any cost effective to maintain the energy efficiency? Absolutely double glaze... different brands of aluminium have different efficiencies. You don't need to go to thermal break, some non-broken windows beat thermal break - ours is one. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Is It Worth Double Glazing for Aluminium Frame Window? 3Jun 23, 2015 2:32 pm ed @ ecoclassic yhfg27 Timber is hard to maintain. If I choose aluminium frame, is it worth throwing a lot to have double glazing windows as aluminum will lose heat quickly and is the weakest point in the chain. Other options like Aluminum broken is costly. Is there any cost effective to maintain the energy efficiency? Absolutely double glaze... different brands of aluminium have different efficiencies. You don't need to go to thermal break, some non-broken windows beat thermal break - ours is one. Ed Emigrating from Scotland, I couldn't believe double glazing wasn't everywhere in Australia. Growing up in the 80s, cold calling and door knocking was commonplace from Double Glazing companies. Both Rangers and Celtic were sponsored by CR Smith, which was a double glazing company. Most people upgraded, because it made so much sense. The fact that new homes are being built with single glazes in 2015 in madness. Re: Is It Worth Double Glazing for Aluminium Frame Window? 4Jun 25, 2015 8:58 am can you give me some examples of non-broken windows? ed @ ecoclassic yhfg27 Timber is hard to maintain. If I choose aluminium frame, is it worth throwing a lot to have double glazing windows as aluminum will lose heat quickly and is the weakest point in the chain. Other options like Aluminum broken is costly. Is there any cost effective to maintain the energy efficiency? Absolutely double glaze... different brands of aluminium have different efficiencies. You don't need to go to thermal break, some non-broken windows beat thermal break - ours is one. Ed Re: Is It Worth Double Glazing for Aluminium Frame Window? 5Jun 25, 2015 9:00 am also are they costly? yhfg27 can you give me some examples of non-broken windows? ed @ ecoclassic yhfg27 Timber is hard to maintain. If I choose aluminium frame, is it worth throwing a lot to have double glazing windows as aluminum will lose heat quickly and is the weakest point in the chain. Other options like Aluminum broken is costly. Is there any cost effective to maintain the energy efficiency? Absolutely double glaze... different brands of aluminium have different efficiencies. You don't need to go to thermal break, some non-broken windows beat thermal break - ours is one. Ed Re: Is It Worth Double Glazing for Aluminium Frame Window? 6Jun 25, 2015 9:04 am So - is it just for heat/cool - or noise as well ? Re: Is It Worth Double Glazing for Aluminium Frame Window? 7Jun 25, 2015 8:50 pm Double glazing in Oz generally has the outer frame of the window as aluminium and the inner frame of timber so that the heat or cold is not transmitted inside. Good for sound prevention as well. Double glazing would normally be combined with a honeycomb type Venetian blind to further prevent transmission of cold or heat Re: Is It Worth Double Glazing for Aluminium Frame Window? 8Jun 29, 2015 4:18 pm Peejayell Double glazing in Oz generally has the outer frame of the window as aluminium and the inner frame of timber so that the heat or cold is not transmitted inside. Good for sound prevention as well. Comes at a cost, about 2.5x double glazing with just aluminium. Re: Is It Worth Double Glazing for Aluminium Frame Window? 9Jun 30, 2015 12:19 pm agree with double glass, it has 35db soundproofing, good weatherproofing. Re: Is It Worth Double Glazing for Aluminium Frame Window? 10Jul 01, 2015 3:22 pm yhfg27 can you give me some examples of non-broken windows? Almost all aluminium windows are unbroken, meaning they are one piece aluminium. Thermally broken aluminium almost always is identified as such. These windows have the outer and inner surfaces separated by a nylon joiner, which restricts the passage of heat inside>outside and v.v. yhfg27 also are they costly? Thermally broken windows are generally 70%-100% dearer than unbroken windows. Peejayell Double glazing in Oz generally has the outer frame of the window as aluminium and the inner frame of timber so that the heat or cold is not transmitted inside. Good for sound prevention as well. Double glazing would normally be combined with a honeycomb type Venetian blind to further prevent transmission of cold or heat Not so, most windows would be 100% aluminium or 100% timber or 100% PVC. The timber and aluminium windows is known as a composite window. Yes it's expensive. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Is It Worth Double Glazing for Aluminium Frame Window? 11Jul 03, 2015 9:43 pm Check out Rylock Windows & Doors. Very happy with their double glazed windows which are timber framed with outer frame aluminium. Australian Made as well Loving my windows. For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7735 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14458 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19261 |
