Browse Forums Windows & Doors 1 Mar 18, 2015 12:49 pm 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Low e glass 3Mar 19, 2015 8:33 pm 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Low e glass 4Mar 19, 2015 8:36 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Low e glass 5Mar 20, 2015 9:19 pm 18/03/15 Deposit 02/09/15 CDC 22/09/15 Slab 05/12/15 Frames 15/12/15 Brick started. 11/04/16 Roof start 04/05/16 Roof finish 09/07/16 Gyprock. Re: Low e glass 12Apr 13, 2015 4:38 pm Adam_C Hi all, Sorry to hijack your thread, but I'm struggling with this as well. My build is yet to start but I will ave two bedroom windows (bed 2 & bed 3) facing West, and have opted for low-e glass on those windows. Given that they will block heat transfer when you don't want it to (IE during a sunny Winter's day) as well as when you do, I'm wondering if they're worth it at all. Adam Good point... Low-E works only on radiant heat... so it's most effective on direct sunlight. which is a very concentrated form of radiant heat. It does work with background heat too, but that is relative to the radiant component. So I would have low-E because it is much more difficult to control very localised incoming solar heat than to heat the home... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 4 6201 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17530 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13765 |
