Hi there,
Does anyone know if it is possible to retrofit louvre type windows to a normal glass window (non-sliding)?
Could/Would the window supplier reuse the frame and modify it to accept louvre windows?
Thank you
Browse Forums Windows & Doors 1 Mar 10, 2015 1:59 am Hi there, Does anyone know if it is possible to retrofit louvre type windows to a normal glass window (non-sliding)? Could/Would the window supplier reuse the frame and modify it to accept louvre windows? Thank you Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Re: Retrofit louvre window to normal window 2Mar 11, 2015 3:23 pm Hootie Hi there, Does anyone know if it is possible to retrofit louvre type windows to a normal glass window (non-sliding)? Could/Would the window supplier reuse the frame and modify it to accept louvre windows? Thank you Possibly... contact Breezway http://www.breezway.com.au/ they supply louvre windows and the louvre galleries to fit into other windows... they will advise a distributor in your area. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Retrofit louvre window to normal window 3Mar 16, 2015 10:44 pm Thanks Ed, I will check with them. Cheers Our Build Thread: The "Extended" Marina by Visionone Homes Our Inspirations: Frank Lloyd Wright | Houzz Yes, get a builder, make sure he is experienced and a registered building practitioner 5 8995 |
