Browse Forums Windows & Doors 1 Jan 15, 2015 5:25 pm I am about to redo my house in pvcu windows. Can anyone tell me whether it is worth getting double glazing on just the side of my house with a noisy street and single glaze the rest? Re: Pvcu windows 2Jan 15, 2015 6:24 pm If you have East or South facing windows they should be double glazed as you loose a lot of heat through windows facing those directions. I would still get it everywhere but if you're strapped for cash I'd do that. Re: Pvcu windows 3Jan 15, 2015 6:25 pm I am in Queensland and don't have heating or cooling in the house, this is only to do with noise reduction Re: Pvcu windows 5Jan 15, 2015 7:32 pm So if I have the double glazed on the street side, but not the others, I was just wondering if the difference would be noticeable enough to make it worth the extra cash Re: Pvcu windows 7Jan 16, 2015 8:55 am You may want to look at sound proofing solutions. I recall reading that if you can get the windows to have a very tight seal then that will also stop a lot of the noise bleed. Double glazed tilt and turn windows will stop a lot of sound and also have a tight seal. To sound proof the gap between the glass has to be quite large to increase the amount of sound that is blocked. Re: Pvcu windows 8Jan 16, 2015 5:41 pm Any reason why you want PVC windows if you are not interested in the thermal aspects? Aluminium double glazed should do the job if it is only a noise issue. My build thread: Custom build on 40 acres viewtopic.php?f=31&t=75656 Re: Pvcu windows 9Mar 02, 2015 10:29 am The pvc windows look exactly like wood but with none of the hassle of wood. They are beautiful Re: Pvcu windows 10Mar 03, 2015 4:07 pm Double glazing will make a very big difference, for example our standard double glazed window stops 34.5 dB... the thicker the glass the better, and it is best if each pane of glass has a different thickness... e.g. 6mm glass, 12mm air and 4mm glass. So we achieve Rw 39 (that's 39 dB stopping power) with 8.76mm x 9mm x 4mm As above, sealing is very important, and aluminium will be as effective as uPVC. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10548 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4591 I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6560 |
