Browse Forums Windows & Doors 1 Oct 22, 2014 8:48 pm We need to choose windows for our house extension. We are located in central Victoria, near Ballarat so cold in winter. Minor bedrooms and home office windows face WNW - windows will be 1800mm wide x 1300mm high. Living area has 2 sets of sliding glass doors (3600mm x 2100mm and 2000mm x 2100), these doors face roughly ESE. The larger door opens onto a fully covered alfresco area, the smaller door opens to a deck which may end up with a pergola. Our heating is a wood heater and we have a split system unit in the living area which is used primarily for cooling. Prime concern is the heat getting in to the rooms facing WNW. We will plant deciduous trees along this side of the house (rural property so no space issues) and probably put an awning of some sort over windows in summer. I know double glazing is not good for keeping heat out but is it still worth double glazing for the winter benefit? Will double glazing make a difference in the living area? If so, both doors or only the one not facing out to the alfresco undercover area? Any advice please? Re: Window options for house extension in central Victoria 2Oct 26, 2014 3:18 pm WNW - double glaze including Low-E ENE - double glaze without Low-E Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4019 Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8986 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8443 |
