Browse Forums Windows & Doors 1 Sep 29, 2014 10:40 am The good news is I have another little one on the way. The bad news is my study needs to be converted into a 4th bedroom. It currently has a double width opening to the hallway but no door frame. For symmetry I was thinking of installing double doors identical to those on my theater room directly across the hallway. This will also mean that the room can be used more flexibly again later. see pic: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The doors are taller than average (a bit over 2.3m high) so I don't think there will be an off the shelf solution. It will also need the frame and architraves built too. My question is who do I get to install the doors? I don't even know if I should be calling a builder, a carpenter or a door company. I think that the external windows and doors were installed by Seaview Joinery as part of the build so they may have installed the internal doors too. Would they be the right people to call or does anyone have any suggestions? Re: Installing new internal doors - Builder or Carpenter? p 2Sep 29, 2014 1:27 pm Carpenter will be able to do the doors, frame and architraves. Then you may need a plasterer and then painter. Straight forward job. 2340mm high doors are a common size available off the shelf. Re: Installing new internal doors - Builder or Carpenter? p 3Sep 29, 2014 4:45 pm JB1 Carpenter will be able to do the doors, frame and architraves. Then you may need a plasterer and then painter. Straight forward job. 2340mm high doors are a common size available off the shelf. Cheers. Would there be any advantage in going with the mob that installed the other doors? I am hoping to get doors matching the existing doors in the house and I don't know how common they are. Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3334 Ask yourself if the insurance company will be aware of the Reno. 4 7496 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6759 |
