Browse Forums Windows & Doors 1 Aug 24, 2014 3:29 pm Hi I have a 3.2M wide by 2.1M wide space where I want to have glazed timber bifolds. My question is if I can have an access door with a 4 panel setup that will still stack all to one side? This would be 800mm wide bifolds. Or to do that do I have to go 5 panels which would be 640mm wide bifolds and may look too narrow. I have also heard that weight may be a factor to consider in order to keep the door from sagging over time? Can anyone advise if I can have a 4 panel bifold with an access door that all stacks to the same side? Re: Wooden Bifold Door Query on Configurations 2Aug 24, 2014 4:17 pm you can have 4 panels with an access door but that is fixed on one side so only 3 panels with go to the other side. 5 panels will give you an accesss door and all panels stack to one side when needed. Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9137 2 7185 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6682 |
