Browse Forums Windows & Doors Re: Wardrobe doors in Perth? 2Aug 16, 2014 9:53 am Can you get away with premade doors? I bought the multi-store ones from bunnings when they were on clearance last year, but it looks like they can still be special ordered. They seem to be built well, only issue I had was finding the side bumpers which I ended up just finding ones for another brand of doors. Also they pre-drill the holes in the wrong places for the top/bottom rails. Would have been better if they didn't bother with the holes. When I was looking most places were charging around $700 per robe. Re: Wardrobe doors in Perth? 3Aug 16, 2014 8:51 pm They are expensive wherever you go. Try Lifestyle Wardrobes in Wangara, they seem to be pretty good value. Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3067 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4896 Hi Stuey, think you’ve got a couple of options here you’d just need to decide your preference/which options suits best. You could recess the windows (just keep in… 1 3994 |
