Browse Forums Windows & Doors Re: 3AW's Big House & Double Glazed Windows. 2Aug 03, 2014 9:22 am Hi I wanted to ask you, I have VANTAGE double glazed windows throughout my house. Can you please explain why 1. The low E glass used on my 4 panel sliding stacker and large 2.3x3m windows (north side) are so hard to clean. In sunlight they look milky and you can never get streak free glass when you clean them. Casement windows on south side in the bedrooms are the only ones that condensate on the inside during the cold nights. How do you know that Argon is actually in the windows. I can see tiny gaps where the seals don't meet in the corners. Thanks Ed. Re: 3AW's Big House & Double Glazed Windows. 3Aug 04, 2014 2:32 pm ![]() Hi I wanted to ask you, I have VANTAGE double glazed windows throughout my house. Can you please explain why 1. The low E glass used on my 4 panel sliding stacker and large 2.3x3m windows (north side) are so hard to clean. In sunlight they look milky and you can never get streak free glass when you clean them. Casement windows on south side in the bedrooms are the only ones that condensate on the inside during the cold nights. How do you know that Argon is actually in the windows. I can see tiny gaps where the seals don't meet in the corners. Thanks Ed. Hi You have found a common problem in single glazed Low-E - e.g. ComfortPlus, it is very difficult to clean, and you must adopt the supplier's method of cleaning. I have included their recommended cleaning procedure below. Is the condensation forming on the glass? Are these double glazed (you mention argon, so I think so). Yes, with rubber glazing (as distinct to silicone - as in EcoClassic), gaps exposed to air can form in the corners. These affect the air (and rain) leakage through the window, but should not affect the double glazing. Argon and low-E are detectable only by using a special instrument. Ed Hand Cleaning Viridian ComfortPlus™, SolTech™, EnergyTech™ and Enviroshield Performance™ Glass These glass products have a very thin coating on the interior glass surface. It is this hard and durable coating which gives these products improved thermal insulation and solar control performance compared to ordinary clear glass. The coated surface of Viridian ComfortPlus™ SolTech™, EnergyTech™ and Enviroshield Performance™ glass does clean differently to ordinary glass and these guidelines are recommended for the most appropriate hand cleaning results. Routine Cleaning: Hand cleaning of the coated (interior) surface, to visibly remove accumulated dust or fingerprints, can be accomplished using a number of different glass cleaning products. The exterior surface of the glass is not coated so can be cleaned in the same fashion as ordinary glass. Recommended Routine Cleaning Products: • Windex® Surface and Glass (clear liquid available from Supermarket), produced by SC Johnson & Son Pty Ltd; or • A mixture of one part vinegar with ten parts water. In addition to the above products, commercially available vinegar-based glass cleaners have generally demonstrated an ability to provide a clean, streak free glass surface. Viridian does not recommend the use of ammonia-base and alcohol-base glass cleaners because these products tend to leave visible streaks. Routine Cleaning Procedure: • While cleaning ensure jewellery and watches are removed and gloves should be worn. • Flood the glass surface with the spray-on cleaning solution or with a cloth saturated with the cleaning solution. Be generous with the amount of solution applied. • Scrub the wetted surface with a clean, lint free towel or cloth. • Wipe dry with a dry, clean, lint free towel or cloth. Do not use a squeegee on the coated (interior) surface.viridianglass.com ABN 55 008 631 356 • To prevent streaking, stop wiping when the glass is almost dry and there is a uniform film of moisture left on the glass surface. The film will quickly evaporate leaving a clean surface. Spot Cleaning: Occasionally spot cleaning may be required to remove stubborn dirt or foreign materials which adhere to the surface. Spot cleaning products work to remove markings from grease, oil, tape adhesive, and crayons or other waxy materials as well as paint and rub-off marks from plastics. Recommended Spot Cleaning Products: • Acetone (solvent available from hardware store) and must be used strictly in accordance with manufacturer’s recommendations and warnings. Spot Cleaning Procedure: • While cleaning ensure jewellery and watches are removed and gloves should be worn. • Apply a small quantity of the cleaner listed above to a clean, wet cloth or towel. • Rub on areas of glass needing spot cleaning. • Wipe clean using a dry, clean, lint free towel or cloth followed by a routine cleaning procedure. Specialised Cleaning: Do not use razor blades, steel wool, scouring bristles or other metallic or abrasive objects on the coated surface. If metallic objects contact the coated surface, a thin layer of metal removed from the object may be deposited onto the surface which results in a discoloured stain which is difficult to remove using normal cleaning procedures. Recommended Specialised Cleaning Products: • Hydrochloric Acid (available from hardware store). Specialised Cleaning Procedure: • While cleaning ensure jewellery and watches are removed and gloves should be worn. viridianglass.com ABN 55 008 631 356 • Carefully follow the chemical manufacturers use and safety instructions. If there are none, pick a brand that has instructions and safety precautions or contact the manufacturer before use or application. • Apply a small quantity of the specialised cleaning product listed above to a wet, clean cloth or towel. A cotton bud may be used for thin line type marks. • Rub on areas of glass needing cleaning. • Wipe clean using a dry, clean, lint free towel or cloth followed by a routine cleaning procedure. • Ensure that the cleaner does not come into contact with framing materials. About This Cleaning Advice: This information is offered as a general guide only and specific advice should always be sought from a reputable glazier or professional window cleaner before undertaking any cleaning. This guidance does not preclude the use of other methods, materials or equipment, however the user should undertake careful evaluation and make suitable enquiries of the suitability of alternative methods, materials or equipment, before using them. Viridian has taken all reasonable care in producing this document, however Viridian makes no representations or warranties, express or implied, as to the accuracy, reliability or completeness of, and disclaims all liability, direct or indirect (and whether or not arising out of the negligence, default or lack of care of Viridian for any loss or damage (whether foreseeable or not)) suffered by the recipient or any other person arising out of, or in connection with, any use or reliance by any of them on this document. Liability which cannot legally be excluded is limited to the maximum extent possible. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 7717 ![]() The enforcement of the new 7 star rating has been deferred until May 2024 in Victoria https://www.energy.vic.gov.au/for-house ... -standards I would assume that means… 13 9237 Building Standards; Getting It Right! Also an expansion joint. It will probably be better to silicon it? What I don't like is that joints between panels are not properly rendered and look ugly. 1 14256 |
