Browse Forums Windows & Doors 1 Jun 26, 2014 7:21 pm Hi all, Wondering if someone can tell me what a storm mould is on a window? I am getting quotes to replace my old timber windows (renovating them is a lot more expensive so I have found out) and I have had a few quotes from window companies, none of which have mentioned storm moulds. Then I had a builder quote me and he has included 'storm moulds' in his quote. Then today I received what I hope is now my last quote where the quote actually identifies storm moulds and their inclusion in the quote (they are not included in the cost). Just wondering what are the benefits and do I need them? Many thanks in advance cheers Stacey Re: What is a storm mould on a window and do I need them? 2Jul 04, 2014 1:28 pm staceyb Hi all, Wondering if someone can tell me what a storm mould is on a window? I am getting quotes to replace my old timber windows (renovating them is a lot more expensive so I have found out) and I have had a few quotes from window companies, none of which have mentioned storm moulds. Then I had a builder quote me and he has included 'storm moulds' in his quote. Then today I received what I hope is now my last quote where the quote actually identifies storm moulds and their inclusion in the quote (they are not included in the cost). Just wondering what are the benefits and do I need them? Many thanks in advance cheers Stacey Assuming timber windows If the windows are properly sealed, you won't need them. But if it's a light weight construction (blue board or weatherboard), then it may be wise because the window may be flush with the wall... they shouldn't cost much... . Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: What is a storm mould on a window and do I need them? 3Jul 05, 2014 12:37 pm Thank you for your reply. I am replacing old timber windows with aluminium - I checked with the company who will more than likely get the go ahead and they said that I didn't need them. So hopefully that will be fine. cheers Re: What is a storm mould on a window and do I need them? 4Jul 07, 2014 8:06 am Just repeating, if it is a weatherboard or light weight wall and the window is flush with the outer wall, then a "Z" flash above the head would be advisable. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: What is a storm mould on a window and do I need them? 6Jul 08, 2014 12:16 pm staceyb Ooops.... never mentioned brick veneer.... which I am rendering after window installation... so no weatherboard. cheers Let your supplier/installer know you will be rendering the bricks, they should leave an 8-10mm margin so that the render runs up to the window and does not foul it. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28448 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7844 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6860 |
