Browse Forums Windows & Doors Re: Re: internal double / french doors - what door width? 2May 15, 2014 12:55 am Not entirely sure but I think I was told that French doors are narrower than normal doors so I'm thinking 770. Re: Re: internal double / french doors - what door width? 3May 15, 2014 11:51 am I don't think there is any "standard" width french door as such. I've seen french doors down to 620mm wide both internal and external but bear in mind when you want to walk though a narrow set of french doors you will have to open them both to do so ( unless you want to squeeze through just one ). For this reason alone I personally wouldn't want each door to be smaller than 720mm wide. But I don't like wider than 820mm double doors either unless you raise their height to say 2250mm to make them visually balanced. It will also depend on whether you can open them both back onto a wall without impeding something else on those walls or whether you don't mind them opening out to just 90º. Stewie Re: internal double / french doors - what door width? 5May 16, 2014 7:06 pm l have 720 x2.4 are perfect,plenty of room to pass through with one door closed Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3260 Thanks again for this information. If you do hear anything different, would be great to know 4 8242 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4121 |
