Browse Forums Windows & Doors 1 Apr 11, 2014 6:15 pm I live in a two storey home with a north west facing glass sliding door that takes up the whole length of one wall in the upstairs master bedroom (opens onto a balcony) The house is late 80's brick veneer but has no insulation and a flat tin roof - it is as hot as hell in summer in the bedroom. Is there any point upgrading the sliding door to double glazed for insulation purposes or are any gains going to be lost due to no insulation in the walls or ceiling? Re: Double glazing a poorly insulated house 2Apr 12, 2014 7:40 am psyninja I live in a two storey home with a north west facing glass sliding door that takes up the whole length of one wall in the upstairs master bedroom (opens onto a balcony) The house is late 80's brick veneer but has no insulation and a flat tin roof - it is as hot as hell in summer in the bedroom. Is there any point upgrading the sliding door to double glazed for insulation purposes or are any gains going to be lost due to no insulation in the walls or ceiling? I think 70% of your problem is your door. Double glazing is great at keeping heat IN but not so good on its own at keeping heat OUT. You need to have low-E glass, preferable in a double glazed unit. Best of all can you shade the door? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double glazing a poorly insulated house 3Apr 12, 2014 9:50 am Thanks for the reply- yes I think shading it may be an option but I also have huge void windows next to the bedroom at the front of the house which let in a LOT of heat so I think I am fighting a losing battle. We have only recently moved into this house and the heat upstairs has been incredible over summer - I have installed split systems in all the rooms upstairs to combat the heat. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Double glazing a poorly insulated house 4Apr 15, 2014 12:54 pm I would fit an aluminium louvre set at 90 degrees to the wall, just above the window/door. The void is particularly easy for a louvre installation. I think it would look good too... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10908 Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3234 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19235 |
