Browse Forums Windows & Doors 1 May 21, 2008 6:02 pm I was wondering if anyone knew how much it'd cost to get a 3 panel sliding white louvered door for our hall storage cupboard?
Is it generally cheaper to buy one from somewhere and get it installed by a tradesman, or to go to one place who will do it all (supply and install)? Also, I am obsessed with white plantation shutters, and wondered if anyone knew of cheap but GOOD quality shutter suppliers on the Gold Coast? I have about 8 places to get quotes from when the time comes. We have 2 large patio doors/windows to get bi-fold or sliding shutter doors on in the living area, then a back patio door/window in the master suite and a smaller window in the study. How much would this cost approx, does anyone know? How the hell did I become a senior member!? I know nothing! Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3077 Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51809 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61389 |
