Browse Forums Windows & Doors 1 Jan 23, 2014 1:45 pm We have been living in a metricon built home for over two years. Upstairs windows are mostly restricted awning windows due to safety regulation - with a large fixed panel at the bottom and a very narrow restricted openable awning panel at the top. This has been proven to be a poor design. Summer is very hot upstairs. I am looking for solutions to improve the the ventilation. Ceiling high is 2.4m, ceiling fan is not practical. Things we have been considering: Change the awning windows to be casement or double hung windows, not sure which one will give the most ventilation when restricted. It is an expensive exercise, not sure if it is any better at the end. apply external solar window films to the windows - assume it is cheaper, but not sure if they are allowed on residential windows and how good they are. Would like to hear your experience with any of the above solutions. Thanks Re: solutions to improve poor ventilation upstairs 2Jan 23, 2014 3:55 pm If you have got east and west facing windows have internal reflective film installed. You will be amazed at the difference it can make and a lot cheaper than new windows. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: solutions to improve poor ventilation upstairs 3Jan 23, 2014 4:01 pm Thermal imaging scan may reveal where most of your heat is coming in and if it's patchy Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: solutions to improve poor ventilation upstairs 4Jan 26, 2014 6:56 am The first floor is always hot in summer (been there, done that), all the ground floor heat rises up, and you have the solar heat gain from the first floor as well. Types of windows, given the same opening won't make a big difference as it is air flow from the pressure differentials (negative and positive) that moves the air. I agree with film, try that first. As well, think about evaporated air conditioning as a cheap solution, or inverter refrigerated. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6367 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7861 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3169 |
