Browse Forums Windows & Doors 1 May 15, 2008 4:03 pm Hi Guys,
Does anyone have a rough idea of the cost of upgrading the entry door from 820mm wide to 870mm wide? I plan on ungrading to the corinthian 4 square panel door which is roughly $650 for an 820mm wide. Just curious if people have gone the 870mm option which then reduces the glass panels on each side of the door. Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11369 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 |
