Install eaves before/after new windows?
The windows haven't arrived yet. Wondering, should I install new eaves before the windows go in, or after?
I have a 1960's brick veneer, and some of the windows run right up to the eaves. I recently had all the eaves removed so the windows could be installed (window company wasn't going to the job if I didn't, as eaves were asbestos).
I assume you are talking about the lining under the eves? In which case probably best to do it after the windows have gone in.
Stewie
7
Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out…
22/12/2023
4
The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's…
11/09/2023
3
I can help you with all that, you can PM me with details if you wish
