Browse Forums Windows & Doors 1 Nov 15, 2013 12:32 am Hi! Is anyone able to recommend someone for stained glass overlays? I have a window almost level with the top of the spa bath that overlooks the neighbour's backyard. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ . I thought an overlay would be a nice way to give us both some privacy. I found these guys online: http://www.stainedglassoverlay.com.au/, their galleries, while finicky, show some truly beautiful window art. Any idea on prices? The window is 146cm H x 181cm W, three panes. Cheers Re: Stained Glass Overlay 2Nov 15, 2013 8:10 am We used cathedral in our ensuite - not quite blank - good light - but not able to see through. Will it have blind/window covering of any sort ? Re: Stained Glass Overlay 3Nov 15, 2013 11:41 pm Saint Mike We used cathedral in our ensuite - not quite blank - good light - but not able to see through. Will it have blind/window covering of any sort ? Hi there! What do you mean by used cathedral, is that the pattern? Do you have any photos? I was thinking I would get reflective tinting on the outside to reduce heat into the ensuite and have a stained glass overlay on the inside. Otherwise I can have a the same window dressings I will have in the bedroom. But I worry about the steam leading to mould if it gets wet from the bath too often and doesn't dry properly. Cheers Hi, We have warm light throughout our house and it sort of makes are already dark stained floor more darker. We always wanted a lighter colourwd flooring but it turned… 0 21469 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 37681 |
