Browse Forums Windows & Doors 1 Oct 30, 2013 3:36 pm Hi Team, I'm constructing a rear entrance to a property which is essential a 300mm double brick wall. The opening is 2770mm wide. I need advice on what type of construction / lintel to use. As it is wide and is carrying a reasonable load and also there is a brick on edge soldier course planned across the head on each side. I am feeling that it will have to be a double sided steel right angled one of some sort. Do lintels like this come as standard or would it have to be custom made? Any good dealers or manufacturers you could recommend? I have attached a drawing of what I am trying to do. Any advice would be greatly appreciated. Thank you in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://imageshack.us/content_round.php? ... 6/4itm.jpg Re: Door Lintel for Double Brick Opening 2Oct 30, 2013 7:56 pm I can't open the attachment You can buy a T lintel off the shelf, it should be 8 or 10mm for that length. I think more bricks are better than less above the lintel as the weight of it will help stabilise it. Double brick walls are 230mm wide and the lintel is 200mm wide. Re: Door Lintel for Double Brick Opening 3Oct 30, 2013 9:57 pm You would need a 150x90 8mm T-lintel with at least 3 courses of brick above. 5 10491 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9979 Double brick homes are the worst type of building conventions for the australian climate 1 1132 |
