Browse Forums Windows & Doors 1 Sep 01, 2013 8:02 pm I have just had 6 very large UVPC(4.6x1. windows and one French door installed. 4 large windows face west, French door north, the rest south. The glass spec is 6.38 Lam / 17mm Air gap / 4mm glass low E surface 3 Even though not specifically noise reduction windows I wanted them installed to help with this aspect if possible. The fitter advised to put the laminated to the outside to aid with this. Two questions I have and cant get straight answers for from the glass supplier. 1. Is it better to have the laminated in or out for max distant traffic rumble reduction. 2. Does it matter that the low E coat is on face 3 on the west facing windows. Baz Re: New Double glazed windows. What way around. 2Sep 01, 2013 8:55 pm Bazzle, low e coating should face into the air gap, mostly to protect the coating. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: New Double glazed windows. What way around. 4Sep 01, 2013 10:03 pm Low e must face out, so it has to be on face 3. Laminate to the exterior @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: New Double glazed windows. What way around. 6Sep 03, 2013 7:17 am I would say the other way round in the West (low-E to surface 2) to reduce solar heat gain... and I don't think it makes any difference acoustically, that you can discern, where the laminated glass is. But it's fairly easy to change that in PVC. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: New Double glazed windows. What way around. 7Sep 03, 2013 10:03 am Thanks ed. I might get one swapped around to see if there is any change to noise . If not it will help with the solar gain (blocking) in summer. I assume you said that way as the air gap can heat up and still transfer heat thru conduction ? Im finding it real hard to get answers from glass manufacturers:( re the noise etc. Re: New Double glazed windows. What way around. 8Sep 03, 2013 3:27 pm bazzle Thanks ed. I might get one swapped around to see if there is any change to noise . If not it will help with the solar gain (blocking) in summer. I assume you said that way as the air gap can heat up and still transfer heat thru conduction ? Im finding it real hard to get answers from glass manufacturers:( re the noise etc. Yes, that's right. As I said in another post, having tested laminated compared to float. the difference is an indiscernible, 1dB. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16235 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 There is evidence of water on the head reveals. That could have happened during the build, or may be happening currently. There are water stains above a couple of windows… 2 3830 |
