Browse Forums Windows & Doors 1 Aug 19, 2013 2:42 pm I've been to the Home Show last Friday, paid a visit to a few windows & doors companies but got confused. So I'd thought of asking some experts on this forum. Is it correct that the bigger the gap between the two panes of glass the better of double glazing? What's the Australian standard in regarding to double glazing? Re: Double glazing question 2Aug 19, 2013 6:06 pm newstart2day I've been to the Home Show last Friday, paid a visit to a few windows & doors companies but got confused. So I'd thought of asking some experts on this forum. Is it correct that the bigger the gap between the two panes of glass the better of double glazing? What's the Australian standard in regarding to double glazing? Hi newstart2day, It depends what you are trying to achieve - and what the cavity is filled with(air, argon etc.) - but typically around 12-14mm is the optimum for thermal performance. Don't forget you really need to compare entire window systems, and the glass is only one particular aspect. Just because one system has a thicker glazing cavity does not necessarily mean it is more efficient system overall. There is no real Australian standard to the cavity size as this varies between systems and what thickness they have been designed to accommodate. Thanks, Kurt Miglas Miglas High Performance Composite Double Glazed Windows Phone 1300 MIGLAS Fax (03) 9728 3555 http://www.miglas.com.au This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19553 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 10122 |
