Browse Forums Windows & Doors Re: Low E glass - are you using it, pros and cons 35Feb 26, 2014 6:52 am Technically, I am sure your designer is right. Practically, I prefer space heating in the winter to spot heating (from solar heat gain from the windows) in the summer... So, I would prefer to block radiant heat which is a point source and difficult to combat in summer, and difficult to distribute in winter, and in doing so, put up with using a little more heating in the winter and less cooling in summer... The cost would be a small difference (if at all), so comfort would be my preference. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Low E glass - are you using it, pros and cons 36Jan 27, 2021 8:25 pm I too have been considering double glazing but as a retrofit in my current house in the Hunter Valley. I had a quote that was just under 20K which included new frames (obviously). As this is out of our price range I had considered looking at Low E glass, however after reading about the thermal shock and other downsides as mentioned previously in the other replies, I'm thinking maybe not. However it does make me wonder if tinting windows would give the benefits of Low E glass without the side-effects. It was suggested I looked at Vortex IR70 Optical Clear by UltraGard as a tint we could put on our windows for a fraction of the cost (about 4K). Apparently it helps keep warmth in in the winter and heat out in the summer. So is tinting current windows as good as Low E Glass without their risk of thermal shock but with all the benefits, or is it the modern magic beans? Thanks in advance for your help. Ollie Re: Low E glass - are you using it, pros and cons 38Jan 31, 2021 6:34 am The thermal shock/Thermal fracture that is first mentioned in the 2nd post on this question by ECOECO. Berek, are you saying the Tint is only recommended for double glazing or Low E glass? Thanks. Re: Low E glass - are you using it, pros and cons 40Feb 05, 2021 11:57 am "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12052 0 2020 4 6201 |
