Browse Forums Windows & Doors 1 Aug 13, 2013 9:23 pm Hi guys, just wanted to get some ideas, should I put the standard timber door frame for laundry and garage back door? or should I put aluminum door frames? is there any advantage of getting aluminum? eg. laundry might be high in moisture and could damage timber frame? is that possible? which one is more expensive? I am going for timber frame for main entrance by the way because I am getting timber entrance door so it matches. just not sure about laundry and garage... Re: Laundry and Garage back door, timber frame or aluminium? 2Nov 24, 2013 5:01 pm I have been putting timber framed doors and doors for nearly 30 years. I must say aluminium has its good side but for a laundry I would probably stick with timber. Re: Laundry and Garage back door, timber frame or aluminium? 3Nov 26, 2013 6:27 am About 50% of people choose timber because it's cheaper. Suitability of aluminium for a garage door depends on the wall construction. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8002 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7712 Move your linen into laundry and access laundry from your present linen space 1 8007 |
