Browse Forums Windows & Doors 1 Jul 24, 2013 9:39 pm I haven't been able to find the answer to my query in other posts, so appoligize in advance if it has been discussed before. We have received a quote for double glazed windows with 6 mm Low E glass 12 mm Gap 6 mm Tinted. When I asked them which is the outside pane of glass. They said either it is up to us. Should the Low E glass be on the outside or the tinted glass? Any info would be great. Thanks Nelso Re: Double Glazed Windows Tinting question 2Jul 24, 2013 9:54 pm I think it depends on why you want the low e, to keep the warmth in in winter(then low e on inside pane) or if you want to keep the radiant heat from the direct sun out (then put low e on outside pane). Although I think the 2nd option is usually why you use low e Re: Double Glazed Windows Tinting question 3Jul 25, 2013 7:46 am JAC is correct, but it is a very complicated question when using a tint because as well as depending where you live, it depends on the colour of your tint. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double Glazed Windows Tinting question 4Jul 25, 2013 12:52 pm Thank you for your responses. We live in Perth. So it is more for keeping heat out in summer. The Tint is Blue Star Grey not overly dark. Just enough to take out some of the glare. So I assume the Low E should be the outside pane and the Tinted Pane inside. Would this be correct? Nelso Re: Double Glazed Windows Tinting question 5Jul 25, 2013 4:27 pm Nelso Thank you for your responses. We live in Perth. So it is more for keeping heat out in summer. The Tint is Blue Star Grey not overly dark. Just enough to take out some of the glare. So I assume the Low E should be the outside pane and the Tinted Pane inside. Would this be correct? Nelso Yes, that would be best as the blue in the tint would absorb and reradiate the red part of the spectrum, so would heat up your room. But the low-E, being on the outside, would filter out 80% of radiant heat first. I assume the low-E is soft coat to the inside of the double glazed unit (not comfortplus), this would be best. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double Glazed Windows Tinting question 7Jul 26, 2013 7:51 am Nelso Thanks for the great info Ed. I will check what type of Low it will be. Does this mean in winter the tint would help keep the warmth in? Cheers Nelso Welcome It's the low-E that will help in winter, Low-E works both ways, just in one direction it is slightly more effective. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double Glazed Windows with low e, question 8Aug 30, 2013 1:40 pm Hi ed, wondering when u add low e, will it reduce thickness of the argon gas in double glazing?.This in regards to the a@ L version of low e (our builder will be using a@l), "comfort smart". I think the comfort smart is their own version of comfort plus.Our builder said its a soft coat.We are wanting to put it east and west where we are not protected from the summer sun.The double glazing will be the whole house.Also what is the best parametres for the double glazing in regards to insulation.thks for your expert advice Re: Double Glazed Windows Tinting question 9Aug 30, 2013 6:31 pm Hi A&L uses the brand ComfortSmart (invented by yours truly) to represent their double glazed products. They use various low-E configurations, so you will need to get the specification for your windows... Check out the different configurations, then ask what you will get.
http://werscpd.net.barberry.arvixe.com/ ... urer=ALVIC "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Double Glazed Windows Tinting question 10Aug 30, 2013 10:44 pm ok thanks ,ill check it out.Also if im trying to stop the radiant heat build up in summer,in respect to double glazing, does the low e coating go on the inside of the outer pane of glass or on the outside of the outer pane of glass or is just the whole outer pane coated on both sides.thks Re: Double Glazed Windows Tinting question 11Aug 31, 2013 7:14 am If you number the glass surfaces from the outside, 1, 2, 3, 4, then in a heating climate it's generally on surface 3, where it keeps the heat inside the home and in a cooling climate on surface 2 where it keeps the heat outside the home. But it is effective in both directions, just not equally. To purely stop solar heat gain, ideally it needs to be on surface 2. Never on the outside. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16154 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16077 |
