Browse Forums Windows & Doors 1 Jun 24, 2013 3:27 pm Hey All, I'm about to kick off a renovation which includes adding some bi-fold or stacking doors to the rear living area. One key factor is having a good flyscreen. I notice there are a lot of retractable screens on the market, but not sure how practical they are. The builder's opinion of them is not high, especially with bi-folds. Is it possible to have stacking flyscreen panels alongside your stacking doors? Thanks, Mud Re: Stackers, bi-folds and flyscreens 2Jun 24, 2013 3:29 pm Oh, while I'm at it, any views on PVC? I'm quite keen on low maintenance and saw some amazingly realistic wood-like PVC doors at the last home show from a company called EuroTech Windows. These windows will be facing west and will cop a lot of sun. Is PVC up to the job ie. won't warp, fade etc? Re: Stackers, bi-folds and flyscreens 3Jun 26, 2013 10:00 am Mudhoney Hey All, I'm about to kick off a renovation which includes adding some bi-fold or stacking doors to the rear living area. One key factor is having a good flyscreen. I notice there are a lot of retractable screens on the market, but not sure how practical they are. The builder's opinion of them is not high, especially with bi-folds. Is it possible to have stacking flyscreen panels alongside your stacking doors? Thanks, Mud I agree with your builder. With stackers, yes, that's how we do it. Some need an adaptor, check your supplier. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Stackers, bi-folds and flyscreens 4Jun 26, 2013 10:02 am Mudhoney Oh, while I'm at it, any views on PVC? I'm quite keen on low maintenance and saw some amazingly realistic wood-like PVC doors at the last home show from a company called EuroTech Windows. These windows will be facing west and will cop a lot of sun. Is PVC up to the job ie. won't warp, fade etc? IMO, having previously supplied PVC for a while, I can say that it does not suit large openings, especially in dark colours. We supply the same timber finish in aluminium. Thanks Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Stackers, bi-folds and flyscreens 6Jun 26, 2013 12:37 pm The temperature differences in Australia which vary by up to 50 degrees, make large windows and doors impractical due to the linear coefficient of expansion for PVC being 5x that of steel, so PVC grows by 6mm over 2000mm over 50 degrees C. Dark colours exacerbate the problem, as surface temperatures can easily exceed 100 degrees, softening the PVC and expanding even more than 6mm. Then there are bushfires... PVC melts at 160 degrees C. etc... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Stackers, bi-folds and flyscreens 7Jun 26, 2013 2:46 pm ed @ ecoclassic The temperature differences in Australia which vary by up to 50 degrees, make large windows and doors impractical due to the linear coefficient of expansion for PVC being 5x that of steel, so PVC grows by 6mm over 2000mm over 50 degrees C. Dark colours exacerbate the problem, as surface temperatures can easily exceed 100 degrees, softening the PVC and expanding even more than 6mm. Then there are bushfires... PVC melts at 160 degrees C. etc... Ed So if I'm doing stackers, the panel size will be limited. What is a reasonable size limit for a PVC panel? Re: Stackers, bi-folds and flyscreens 8Jun 26, 2013 7:20 pm Mudhoney ed @ ecoclassic The temperature differences in Australia which vary by up to 50 degrees, make large windows and doors impractical due to the linear coefficient of expansion for PVC being 5x that of steel, so PVC grows by 6mm over 2000mm over 50 degrees C. Dark colours exacerbate the problem, as surface temperatures can easily exceed 100 degrees, softening the PVC and expanding even more than 6mm. Then there are bushfires... PVC melts at 160 degrees C. etc... Ed So if I'm doing stackers, the panel size will be limited. What is a reasonable size limit for a PVC panel? Not so important in sliding windows and doors, as they have such wide tolerances. Critical in awning and casement windows, and hinged doors. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9882 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19968 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10665 |
