Browse Forums Windows & Doors Re: Gaps in external doors 21May 20, 2013 9:20 am Hi ed, I've just seen your suggestion regarding the mushroom stop on the inside. That's not a bad idea at all. It should work if we stop it short of the lintel at the top and the threshold at the bottom. I'll pass your post on to the boss. Re: Gaps in external doors 22May 20, 2013 10:42 am Liliana Hi ed, I've just seen your suggestion regarding the mushroom stop on the inside. That's not a bad idea at all. It should work if we stop it short of the lintel at the top and the threshold at the bottom. I'll pass your post on to the boss. I think so. But I would take the one off the front and get a narrower one so it fits snug up to the striker plate and so that it misses your handle and lock. No cut outs... then it should look like a shop bought one !!! Pretty close anyway. Post a pic when it's finished. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Gaps in external doors 23May 30, 2013 10:24 pm Hi Liliana I have a simple solution for you Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ To fix gap between doors you need to plant 45x8mm timber strip to hinge side of one door then rehang and dress to even door margins With twist in your door, close door against 20mm spacer at bottom and screw fix top for a week. This will give twist in opposite direction. Timber will creep under stress and this should straighten your door.. good luck Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7465 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19156 Sorry I missed this, simply put this is a pathetic job, and as it stands it is non-compliant... I think the worst part is not in the quality of the workmanship so much… 5 7041 |
