Browse Forums Windows & Doors 1 Apr 14, 2013 7:45 pm Does anyone have a pull handle external door and can explain whether is it easy to lock yourself out? Eg you go out to check the mailbox, you close the door behind you because it is cold and you don't have a key on you. Because there is no handle to turn, does the door automatically lock behind you? How does it work? Thanks. Our build: viewtopic.php?f=31&t=64705 Re: Pull handle external doors- easy to lock yourself out? 3Apr 14, 2013 11:36 pm Our Omi pull handle front door actually has a normal leaver door handle vertically behind it it so you can leave it unlocked pull it behind you and go back inside if you want, it only locks if you have pushed the tri lock button on the inside before you close the door. Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Pull handle external doors- easy to lock yourself out? 4Apr 15, 2013 7:03 am ah ok.. I see, thanks~ Because I really like the look of them! Our build: viewtopic.php?f=31&t=64705 Re: Pull handle external doors- easy to lock yourself out? 5Apr 15, 2013 9:04 pm Hi, has anyone seen a front door handle like Omni but with a knob on the inside? Or even an omni with the same handle on the inside as out? I like the omni but I am thinking about putting a Corinthian Calypso merbau louvre on the front door and having the glass louvre one for my laundry door. I know from previous houses I have built where the clients have used this door, the louvres won't open fully in the middle section as it hits the handle (when using lever sets). The only other option I can see is to use a pull handle inside and out and have a roller catch mortice lock, but I don't really like removing the amount of timber you need to install the mortice lock! Especially when it is only really timber frame around a louvre gallery! Re: Pull handle external doors- easy to lock yourself out? 6Jun 07, 2013 9:39 pm My sister was complaining about her new door that has a pull-handle on the outside. If it's latched, it's locked from the outside. If it's not latched it won't stay closed. The other problems with this, apart from locking yourself out: When you're expecting guests or the kids home from school you can't leave it unlocked but closed; to garden in the front yard, etc you'd have to take your keys; as a guest, if you go to get something from your car, you either have to leave the door open (& hope no one shuts it) or knock and get them to let you in again. At my sister's this is exacerbated by her not having a screen door at all. Re: Pull handle external doors- easy to lock yourself out? 7Jun 08, 2013 1:57 pm kylie, I would find that annoying. We decided not to for a pull handle in the end, as with the deadlock it would have been close to $500 more than a normal handle! Our build: viewtopic.php?f=31&t=64705 Re: Pull handle external doors- easy to lock yourself out? 8Jun 08, 2013 3:12 pm I know you've already decided, but I've got the Gainsborough pull handles and no normal door handles. You never lock yourself out, it's impossible. You need to physically lock it with the key from outside, or you can lock it from inside with the key. I leave mine unlocked so that when people come home they just push the door open and walk in. You definitely don't need to pay all that money for the Omni trilock system. GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Pull handle external doors- easy to lock yourself out? 9Jun 19, 2013 9:34 pm Quote: know you've already decided, but I've got the Gainsborough pull handles and no normal door handles. You never lock yourself out, it's impossible. You need to physically lock it with the key from outside, or you can lock it from inside with the key. I leave mine unlocked so that when people come home they just push the door open and walk in. Maybe I misunderstood what a pull handle is. When you say they just push the door open - you mean without turning a handle or anything? How does the door unlatch? I'd like to get that, whatever it is. Re: Pull handle external doors- easy to lock yourself out? 10Jun 20, 2013 2:37 pm It's called a pull handle but coz its on the exterior of the door, you push the door. The door just opens. So imagine a normal internal door, when its shut that little quarter round metal piece sticks into the door frame but when u turn the knob or handle it pulls it in and u can freely push the door open. Well with my double entry doors, it's just the weight of the pushing of the door that makes the quarter round metal thing retract inside the door and away from the second door. The main door has the metal bit and the second door has the hole that accepts the protruding metal thing. So if there was a really crazy big wind, and the doors weren't solid, it would just blow open, coz the only thing holding it closed is that metal protruding thing holding it into the other door. Hope that isn't too cryptic of an explanation lol! GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Pull handle external doors- easy to lock yourself out? 11Jun 20, 2013 2:39 pm Having said all that, you still have to push pretty hard to open the door, and when exiting the house, you pull hard too. All my visitors get so confused coz they try to turn the dummy handle and it doesn't even do anything hehe GOODLIFE - Bravo - BUTLER http://getmistyfied.blogspot.com.au Display 20/02/2012 PPA 01/04/12 Prestart: 25/07/12 Settlement: 31/07/2012 Contracts:August Slab 19/11/12 BRICKS 10/11/12 Roof 16/01/13 Re: Pull handle external doors- easy to lock yourself out? 13Jun 20, 2013 5:11 pm We have long pull handles as well as a touch pad lock for the whole locking yourself out reason - this way the kids can't accidentally lock us out - anyone who has the code can enter the house (handy for family and friends too). Some things are worth waiting for. Re: Pull handle external doors- easy to lock yourself out? 14Jul 05, 2013 12:21 pm kyton We have long pull handles as well as a touch pad lock for the whole locking yourself out reason - this way the kids can't accidentally lock us out - anyone who has the code can enter the house (handy for family and friends too). Hi kyton, what touch pad have you got? What happens on inside to lock it? Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5171 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 |
