Browse Forums Windows & Doors Re: How to fix leaking windows? 4Apr 06, 2013 1:50 pm SFC Thanks for your reply Ed, I did tip water in the track prior to the corners being sealed and water came out and down the outer wall but also came in and was seen in the subfloor space too. Will toughened glass offer improvements in thermal and noise properties? Is there any point without upgrading the frames? Thanks Steve Hi Steve, I don't undertand how water is escaping into your home from the track when the corners are sealed. Post some pics of the sill, are there drain holes that have been covered up and are leaking under the render and into your home? Toughened glass offers no thermal or acoustic benefits. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5151 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5970 |
