Browse Forums Windows & Doors 1 Mar 14, 2013 2:47 pm Hi, I had my door frame made on site, Vic Ash frame except for the door sill which is Jarrah. Anyway as they are custom made, they don't have any built in weather sealing. I need the weather seals for the sides and door seal to stop droughts and dust. The door seal doesn't have to lift up to clear carpet as I have floorboards. Also the door seal needs to be long enough to suit my 1200mm door. Can you recommend one or a place to get it that will work well. Re: Best weatherseal and doors seals 3Mar 14, 2013 8:11 pm Had a couple ones like that on my doors for about 10 years now and they seem to work ok .. wont stop all the air but stops any water getting in under the door. I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6520 I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1414 Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10931 |
