Browse Forums Windows & Doors 1 Feb 26, 2013 4:36 pm Hi, I'm wondering if anyone can shed any light on how hard it would be to convert a single glaze window into a double glaze window post handover? Does the entire window frame need to be replaced as well? I'm in the contract stage with a builder and the double glazing quote seems excessive so am trying to understand if there is a way to upgrade post handover. Thanks! Re: Convert from Single Glazing to Double Glazing 2Feb 26, 2013 6:53 pm Its not really possible to 'convert' most windows from a cost perspective. Depending on how flexible your builder is you would be better off taking the glazing out of the contract and sourcing them yourselves. How much more is he asking and how much glass do you need? Re: Convert from Single Glazing to Double Glazing 4Feb 26, 2013 9:53 pm Serenity_Now Hi, I'm wondering if anyone can shed any light on how hard it would be to convert a single glaze window into a double glaze window post handover? Does the entire window frame need to be replaced as well? I'm in the contract stage with a builder and the double glazing quote seems excessive so am trying to understand if there is a way to upgrade post handover. Thanks! If you have sliding windows, then, generally no... if you have awning windows, check with your window supplier. They usually use the same system for single and double, but you will need new glazing beads. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Convert from Single Glazing to Double Glazing 5Feb 27, 2013 3:27 pm Thanks all for the info. We have requested for awning windows throughout and without going into full details for each window, I have counted a total of 23 windows (its a double storey house). The builder has quoted (roughly) - $12,000 for double glazing to be applied to ~80% of the windows. This seems excessive as when I spoke to Stegbar they had indicated that the cost difference between a single glaze and double glaze was only ~15%. consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6628 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19244 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8200 |
